Activity Forums Apple Final Cut Pro Legacy Audio Capturing
  • Audio Capturing
    Posted by Charles Ferran on January 26, 2009 at 6:53 pm
    I do not know if this is a Final Cut issue, our company has been up until now just capturing straight audio from a Canon GL2, with no problems. Now we have a shotgun, and a wireless lav mic set up. We had to get an adapter for the audio which is a BeachTek DXA-4P, it has XLR inputs, and thats what we’re using. When I capture the audio now, the audio is always out of sync by roughly two seconds (audio starting later than the video) is this a capturing issue? since I have two channels coming in, or is it an equipment issue, we’re just trying to narrow down the problem in our production pipeline.
    Charles Ferran replied 17 years, 7 months ago 2 Members · 4 Replies
  • Jaap Verdenius
    January 27, 2009 at 7:18 am
    What are things like on the tape?
  • Charles Ferran
    January 27, 2009 at 10:16 am
    the tape looks and sounds fine, I even spoke with the BeachTek people, they say it must be a Final Cut issue, they of course don’t know what :-/
  • Jaap Verdenius
    January 29, 2009 at 7:21 pm
    It sounds like an FCP issue, but I cannot find the relation between the two (yet).
    Is there a possibility that something has changed to the audio sample rate on the camera, that it perhaps to 32kHz instead of 48kHz?
  • Charles Ferran
    January 29, 2009 at 7:34 pm
    well, the GL2 doesn’t have an option for the audio sample rate that I can see, the only audio option at all really is the audio mode which only gives two options, 16bit, and 12bit.
