Activity Forums Apple Final Cut Pro Legacy Audio captured separately to recorder, drifting – I’m losing hair.
  • Audio captured separately to recorder, drifting – I’m losing hair.
    Posted by Bryan Roberts on November 7, 2009 at 12:04 am
    So a multicam show I’m editing was supposed to be sending all the final sound to the cameras and then have the mixer record to files as backup. Well, of course, they just kept all the final sound on the recorder and just recorded on camera sound on each of the cameras – so now I have to sync it all up. I have slates to sync to – the project was shot SD 24p on the HVX to miniDV tapes. I’ve captured into FCP 7.0 and have my cameras all synced up. Now I’m bringing in my post sound (in WAV files) and matching it up to the tapes in a 29.97 timeline (it’s for broadcast). My final WAV audio sound files drift progressively more and more throughout the clip and the mixed final WAV sound files gets further and further behind my picture. In the TC rate of the WAV files while in FCP, it lists them at 24 fps which I know audio doesn’t work on a frame rate but wasn’t sure what else to check. How the hell do I fix this?
    Thanks in advance…
    FCP 7
    24p SD footage from HVX captured with the NTSC DV easy setup preset
    Editing on a 29.97 timeline (no render bars on top, it’s correct).
    OSX 10.5.8
    Intel 3ghz quad, 12 gigs Ram
    FCP / AVID EDITOR
    Features : Television
    http://www.DefiningFilms.com
    Bryan Roberts replied 16 years, 10 months ago 4 Members · 6 Replies
  • Michael Gissing
    November 7, 2009 at 12:31 am
    Try slowing the audio files by .1% . It sounds like you have a drift caused by the difference between true 24 fps and NTSC frame rates that are .1% off true.
  • Aaron Neitz
    November 7, 2009 at 12:32 am
    Kindly do a search. This has been covered many times.
    Your audio is running in real-time. Basically 30.0fps. You need to slow it down. 99.99%
  • Bryan Roberts
    November 7, 2009 at 12:35 am
    Sorry, and thank you.
    FCP / AVID EDITOR
  • Bryan Roberts
    November 7, 2009 at 12:47 am
    Strangely enough, I had to change the audio to 100.1% rather than slow it down to make it sync… weird.
    FCP / AVID EDITOR
  • Adam Smith
    November 7, 2009 at 2:23 am
    I’m guessing 100.1% duration as opposed to playback speed.
    FCP always gets me with that when I’m trying to tweak speed on video clips – the percentage is the opposite of what I naturally think to do.
    Video Photographer / Avid & Final Cut Editor
  • Bryan Roberts
    November 7, 2009 at 2:37 am
    Changing the percentage in the “rate” window…
    FCP / AVID EDITOR
