Activity Forums Apple Final Cut Pro Legacy Audio capture volume too Low
  • Audio capture volume too Low
    Posted by Ed Stevens on April 2, 2005 at 8:42 pm
    First the equipment I am using;
    Apple G5 dual 2.5 FCP
    Blackmagic Deklink extreme board.
    Mackie 1604 mixer.
    I put tone into my mixer and adjust everything to zero. FCP meter reads -24.
    I went into capture pref. and advanced to set gain higher. Nothing happens.
    How can I set this so FCP reads -12?
    Thanks to everyone in advance.
    ED
    Michael Gissing replied 21 years, 5 months ago 3 Members · 3 Replies
  • Mark Landman
    April 2, 2005 at 9:48 pm
    Open System Preferences (under the Apple Menu, not the Final Cut System Setting)
    Click on ‘Sound’
    Select the input device and turn up the input volume slider
  • Ed Stevens
    April 2, 2005 at 11:29 pm
    I appreciate the help but it did not work. Nothing moved at all when I increased the slider.
    ED
  • Michael Gissing
    April 3, 2005 at 10:54 am
    If you have an external mixer, adjust the gain prior to FCP. I assume you are going into the Decklink card via AES. 0VU reference tone should align to -20db on the FCP meters.
