Activity Forums Apple Final Cut Pro Legacy Audio capture
  • Posted by Matthew Daday on November 9, 2006 at 3:40 pm
    Hello,
    We are capturing SDI from a DIGIBETA deck with a KONA LH card. For some reason our cpatured audio is coming in at 2db lower than what we are seeing on the tape. We have gone through every setting in FCP and on the KONA that we can find to see if we can locate an issue. A workaround we have come up with is to trim the audio on the deck 2 DB higher so it comes in where we want it. When mastering to tape the settings are right where they should be. We don’t want to be cheating like this for our whole production, so does anyone have any thoughts?
    Thanks in advance,
    Mathew
    Matthew Daday replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
