Activity Forums VEGAS Pro Audio but no video (black screen)
  • Audio but no video (black screen)
    Posted by Tyler Wentzel on August 12, 2010 at 10:08 pm
    I have tried unclicking the “Show Video Monitor” icon suggested by others in the forums to no avail. I have tried the video in 2 different file formats: .mov and .mp4 video. Both are openable and savable in Vegas, yet neither allowe me to watch the video. There is a video track and its audio track counterpart, but when I try to play it back, I only receive the audio feed.
    Any help would be much appreciated.
    Tyler
    John Rofrano replied 12 years, 1 month ago 5 Members · 6 Replies
  • Anthony Scudieri
    August 12, 2010 at 11:17 pm
    Wait, there is no video AFTER you render? (My problem).
    If there is no video showing up in the timeline, like, the inserted media just is black, uninstall Quicktime player and download an earlier version like 7.5.
  • Tyler Wentzel
    August 13, 2010 at 1:31 am
    Hey thanks for the reply.
    It actually produces no video prior to and following rendering. I tried downgrading to Quicktime 7.6.6 or something like that. No dice.
    Tyler
  • John Rofrano
    August 13, 2010 at 12:13 pm
    There are two reasons for video but no audio:
    1. You do not have the proper Video For Windows (VFW) video codec installed on your PC to decode the video.
      Solution: Use a free utility like GSpot to determine what codec you need and find a VFW version of the codec.
      (Important note: Vegas cannot use DirectShow codecs. Only VFW codecs will solve your problem)
      (Even more important note: The 64-bit version of Vegas requires a 64-bit version of the codec. 32-bit codecs will not work with Vegas Pro 64-bit)
    2. The file is Quicktime MOV format and you are using a version of Vegas older than Vegas Pro 9.0e with a Quicktime newer than 7.6.4
      Solution: Get Vegas Pro 9.0e or uninstall Quicktime and re-install Quicktime 7.6.4 or earlier.
    One of those two should be your problem and solution.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • David Ramel
    March 8, 2011 at 11:40 pm
    FYI, if anyone is still having this problem, TechSmith as of October 2010 does have a 64-bit codec. See:
    https://techsmith.custhelp.com/app/answers/detail/a_id/2793/~/do-you-have-a-64-bit-tscc-codec%3F
  • Glo Dewiccan
    April 17, 2014 at 5:15 pm
    After trying like 20 other suggestions I saw yours, and.. JOY! I can see the MP4 video now in Sony V8.
    Sending good Karma your way ..
  • John Rofrano
    April 17, 2014 at 7:08 pm
    [Glo DeWiccan] “After trying like 20 other suggestions I saw yours, and.. JOY! I can see the MP4 video now in Sony V8. Sending good Karma your way ..”
    You’re welcome. I can always use some good Karma. 😉
    ~jr
