Activity Forums Adobe Premiere Pro Audio bug-audio not playing Pan set to “nan”
  • Audio bug-audio not playing Pan set to “nan”
    Posted by Renny Mccauley on February 19, 2014 at 4:17 pm
    I opened up my project this morning to discover that a good portion of the audio is not playing back properly. Some clips are playing back fine, but others don’t make any sound. They have waveforms in the timeline, but they make no sound when played and the meters don’t show anything. When I match frame from the timeline, the clip will play back properly in the source window, but it won’t play in ANY sequence.
    I dumped my media cache files and let the project re-create the cache, but this doesn’t seem to do anything. I’ve restarted the computer, reset the PRAM, repaired disk permissions, but nothing is helping. In some cases I have nested multicam audio. The nest does not play audio, but when I open it up to reveal all the various sources, that timeline plays back fine. In other cases, a simple music file won’t play back properly. I’m out of ideas on how to fix this. What’s going on?
    Update: Just discovered that I share this same problem with others, that the pan is getting set to “nan.” Nobody seems to have a solution from what I’ve seen. Anybody here found a solution?
    Renny
    Renny Mccauley replied 12 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
