Activity Forums Avid Media Composer Audio Buffer Underrun: DV Device
  • Audio Buffer Underrun: DV Device
    Posted by Jk Video on July 18, 2007 at 8:41 pm
    Hello: I have a MAC G5 Dual 2Mhz, 2 Gig RAM, External Sata Array for storage. I am running Avid Xpress 5.7.2 with QuickTime 7.1.6. Everything is to spec with system requirements. I only have a DV deck connected to the system. The problem is that every time I begin to digital cut/timeline playback after a certain amount of time, I get the error Audio Buffer Underrun: DV Device. It happens almost all of the time now. Mixing down the video and audio and placing them on the system drive doesn’t help either. The funny thing is, it will happen even if there are no audio tracks in the sequence. I contacted Avid already…they are looking into it. I was using Xpress Pro 4.8 with no issues what so ever…until I upgraded. Any help would be appreciated.
    Jk Video replied 19 years, 1 month ago 3 Members · 5 Replies
  • Jk Video
    July 18, 2007 at 9:25 pm
    I was meaning to say 2 Ghz processors. Thank You
  • Grinner Hester
    July 18, 2007 at 9:39 pm
    I get this sometimesd when I try to play starting from an audio dossolve. Puzzling since it happens with you where thre is no audio.
    What happens when you create new user settings and try to play?
    This often cures alot of woes.
  • Koolcat
    July 18, 2007 at 10:50 pm
  • Jk Video
    July 19, 2007 at 2:31 am
    Thanks for the insight. I have never had the issue before. It happens on both short (4min.) and long (1hr 37min.) sequences randomly.
  • Jk Video
    July 19, 2007 at 5:17 am
    Hello again: After looking at the AVID knowledge forums in avid.com’s support area, this seems to be a very large problem. Many people seem to be having this problem. I had to export a QT file and play it back through iMovie to make a DVCAM master. That was a first! I am glad my client was not around.
