Activity Forums Blackmagic Design Audio buffer error in Media Composer
  • Audio buffer error in Media Composer
    Posted by Julian Roberts on February 4, 2012 at 8:30 pm
    I’ve been trying to capture from HDV tape (in 1394 mode via Firewire 800 ) in MC6, but 30 or so seconds in I get the audio buffer overrun error message. I’ve searched the Avid forums and the net, but the only threads I can find go back a number of years.
    One thread I found suggested increasing the audio buffer setting in the Audio Settings. However, I don’t seem to have this option in the Audio Settings dialogue. If I was running Media Composer in software only mode, I should see this setting, but with the Decklink Studio 2 card installed I don’t!
    Can anyone please suggest how I increase the audio buffer, fine the setting has been blanked out?
    Thanks very much
    Julian
    Ari Zlatin replied 14 years ago 3 Members · 9 Replies
  • 9 Replies
  • Krishna Sadasivan
    February 6, 2012 at 1:22 pm
    Dear ,
    So this is a known issue .Facing the same problem ditto ,with the BMD Intensity Pro card . I have already reported this to BMD !!!!
  • Julian Roberts
    February 6, 2012 at 8:00 pm
    Hi Krishna
    Thanks for your response. Are you saying that you can’t capture HDV in Media Composer, and get the same error message? And that this is a know issue linked to the BMD drivers?
    I would be nice in a way to know I’m not alone…
    I wonder if this problem started with Media Composer 6.
    What advice did you get from BMD?
    Julian
  • Krishna Sadasivan
    February 6, 2012 at 8:19 pm
    Dear Julian ,
    We started to get to use BMD cards only starting with MC 6.
    Capture over 1394 (I tried SD ,PAL DV ) has the Audio buffer underrun issue after 10 -15 secs of capture when the BMD Card is installed and MC 6 is kind of automatically locked to it . As soon as the drivers are uninstalled and MC 6 does not see the card anymore ; Firewire capture is absolutley OK !!!
    I am waiting for a reply from BMD ,and I have also made them aware of your case (this thread) to prove my point that this is really a known issue . Good to have someone to share the grief ; and hope it gets solved ASAP . Meanwhile also try out the 9.2B Drivers on the site as it say there are some MC 6 improvements . I am downloading it at the moment .
    Regards
    Krishna S
  • Julian Roberts
    February 6, 2012 at 9:55 pm
    Thanks for the update. Well – if it’s a BMD issue, that solves the mystery of why I’m not getting any feedback on the Avid forum.
    Pls let me know how you get on with the new Decklink drivers.
    I hear Avid is due to release a dot update to MC6 later today.
    Julian
  • Krishna Sadasivan
    February 6, 2012 at 10:12 pm
    Dear Julian ,
    Try the 9.2 BETA driver . I think the issue is fixed !!!
    Regards
    Krishna S
    SSD SYS
  • Julian Roberts
    February 7, 2012 at 8:12 pm
    Seems to work just fine now – great. I don’t get anything through my client monitor when capturing – do you?
    Julian
  • Krishna Sadasivan
    February 8, 2012 at 1:03 am
    Dear ,
    Since we are using the 1394 bus for capture it will not reflect thru the BMD. Only timeline playback will give u client monitor output !!
    Happy editing !!
    Regards Krishna S SSD SYS India
    ▶ Show quoted t
  • Krishna Sadasivan
    February 8, 2012 at 1:04 am
    Dear ,
    Happy editing !!
    ▶ Show quoted t
  • Ari Zlatin
    September 12, 2012 at 7:42 pm
    I can not capture the video vis iLink into Avid Media Composer 6.0.3
    I get Audio buffer overrun error after 2 minutes of capturing HDV from Sony FX7 cam.
    I use Asus Sabertiith Z77 MB on board audio card. Never had a problem with Avid MC 5.5 or 6.01
    Help?
