Activity Forums Panasonic Cameras Audio Breaking Up Ch1
  • Audio Breaking Up Ch1
    Posted by Brett Frame on September 18, 2008 at 7:39 pm
    Just got the HVX200. I have found that CH1 XLR input is being overdriven no matter how low I turn the input level. I have tried a lapel mic and a mic using phantom power. Same results. CH1 through the internal mic seems fine.
    If I use CH2 internal or XLR everything sounds great on both mics.
    Am I missing something or do I need to put this back in the box and send it back?
    Thank for any input,
    Brett
    Brett Frame replied 17 years, 12 months ago 3 Members · 4 Replies
  • Vince Becquiot
    September 20, 2008 at 5:37 pm
    Did you check the mic switch in the front of the camera?
    Most dynamic mics need Mic input, while many wireless, or mixer outputs will need Line. Also check your audio gain in the menu.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    Santa Rosa, CA
  • Brett Frame
    September 21, 2008 at 5:22 am
    Thanks for the reply. Yes I did take a look at all of those things with no luck. Waiting for a word back from Panasonic as well.
    Thank you,
    Brett
  • Jan Crittenden livingston
    September 21, 2008 at 10:13 am
    If the mic you are using works fine on Channel 2 and you have the input levels set the same in the menus along with the external switches and Channel 1 is still a problem, sent in in for repair.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HVX200, DVX100
    Panasonic Broadcast & TV Systems
  • Brett Frame
    September 26, 2008 at 4:55 pm
    Hello All,
    We sent the unit back to where we purchased from. We got a new unit and all inputs work great. Something on the first unit must have been out of whack.
