Activity › Forums › Apple Final Cut Pro Legacy › Audio blips in timeline, but not in audio file
  • Audio blips in timeline, but not in audio file
    Posted by Mark Drewe on November 24, 2009 at 3:08 pm
    I’ve got some audio clips in my timeline that seem to have blips in them when it plays through and when it renders (sometimes) – however when I play the original audio file outside of FCP there’s no blips. Is there any way I can resolve this issue?
    John Fishback
    replied 16 years, 10 months ago
    2 Members · 2 Replies
  • Mark Drewe
    November 24, 2009 at 8:12 pm
    That worked perfectly. Thanks!
  • John Fishback
    November 24, 2009 at 9:42 pm
    If you’re using a Kona card without a ref signal fed to it, that can produce noise in the signal.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
