Activity Forums DVD Authoring Audio being goofy
  • Audio being goofy
    Posted by Jonathan Capra on November 10, 2005 at 5:08 pm
    I am using DVD Architect
    I created an NTSC 29.97 Widescreen DVD project and imported an MPEG video stream file made in Vegas using its NTSC Widescreen DVD Architect preset. Strike that.. I first went into the custom settings and changed it to a fixed 9.8mbps data rate.
    Then I separately created a stereo AC3 file at 384k. I brought them both into DVD Architect, built and burned.
    I put the disc in my home player and it works fine except if I manually skip to another chapter mark, it will play with no audio. Audio wont resume unless I pause it and hit play again.
    Any ideas?
    Jonathan Capra replied 20 years, 9 months ago 2 Members · 2 Replies
  • Dr. Dropout
    November 17, 2005 at 11:11 pm
    Your aggregate bitrate is too high. Try re-rendering the video with the stock template.
  • Jonathan Capra
    November 18, 2005 at 12:13 am
    Yeah that’s what I did. It worked flawlessly. Thanks..
    For really short presentations, I like to use a fixed bitrate on the video. I could swear I’ve done 9.8 coupled with 384 audio on a Mac and had it work ok. But it might have been 9.0 now that I think about it.
    If I want to use 384 audio, what is the max bitrate I can have on the MPEG-2? When I am filling the disc, I am fine using variable. But for this project, it was 5-6 min total of some really stellar camerawork where I had troubled to keep it at 4:2:2 uncompressed during the post-production process.. So I wanted to compress it as little as possible for delivery.
