Activity › Forums › Avid Media Composer › audio batch import too short!!!!!
Posted by German Rubio on May 23, 2006 at 12:08 pmS
German Rubio replied 20 years, 3 months ago 3 Members · 3 Replies -
Chris1621
May 24, 2006 at 9:35 amIf all else fails, you could always import the audio file normally, place it in a new sequence and pad it to the right length, export it to a new file and then batch import that one. Long winded but it should work!
German Rubio
May 24, 2006 at 11:19 amThank to all….
the bit rate, and sample rate was exactly the same!!!!!! i cant understand it.
Finally i imported again and made all the cuts and normalize…. more work, but the deadline was over…..
Thanks again for your support!!!!!!!!!!!
NOw the problem its another one……i will paste it here…..
