Activity Forums Adobe Premiere Pro audio balancing help
  • audio balancing help
    Posted by Marc Dejesus on November 15, 2008 at 12:36 am
    hi,
    any help would be appreciated. Ive been used to editing on avidxpresspro the past couple years… and theres a button u push to balance both left and right audio channels.
    my question is.. in premeire cs3, both the left and right channels of the audio are independent… is there any way to channel every audio stream so that the master mix is the result of all the channels being mixed together in this way, both right and left channels of the master mix appear the same, not independent??
    hope this makes sense.. thanks in advance
    Eddie Lotter replied 17 years, 10 months ago 2 Members · 1 Reply
  • Eddie Lotter
    November 15, 2008 at 4:08 am
    [marc dejesus] “hope this makes sense..”
    Not entirely. 🙂
    I suspect these tutorials will help you understand how audio is mixed in PPro.
    Cheers
    Eddie
