Activity › Forums › Apple Final Cut Pro Legacy › audio autosyncing
  • audio autosyncing
    Posted by Craig Anderson on May 31, 2005 at 3:25 pm
    Hi there,
    I have been trying to find out if/how I can auto sync video and audio from 2 sources. Ideally, I would like to set ins and outs on audio from a CD and video, and have them be considered 1 clip. I know I can just do this in a sequence and then nest them, but if I would rather have them as a clip. Does anyone know how to accomplish this?
    Craig
    Francisco Espinosa replied 21 years, 4 months ago 2 Members · 2 Replies
  • Francisco Espinosa
    June 1, 2005 at 3:44 pm
    Do you have FCP 5? Try to make a multi-clip…Multicam Editinglets you “Simultaneously view and cut from multiple sources in real time, thanks to new multicam editing for DV, SD and HD. Group up to 128 sources together into multi-clips, then add or subtract cameras at any time for maximum flexibility. Switch from shot to shot, with or without effects, and auto-assemble sequences based on time-of-day timecode.”
    June 1, 2005 at 3:45 pm
    Do you have FCP 5? Try to make a multi-clip…Multicam Editing lets you “Simultaneously view and cut from multiple sources in real time, thanks to new multicam editing for DV, SD and HD. Group up to 128 sources together into multi-clips, then add or subtract cameras at any time for maximum flexibility. Switch from shot to shot, with or without effects, and auto-assemble sequences based on time-of-day timecode.”
