Activity Forums DaVinci Resolve Audio Auto Sync – Is it possible to slip audio after auto syncing?
  • Audio Auto Sync – Is it possible to slip audio after auto syncing?
    Posted by Craig Harris on October 17, 2012 at 2:54 pm
    The auto sync works great!
    However, the timecode from audio isn’t always bang-on with the camera. Usually I see it drift 1-3 frames throughout the day.
    Is it possible to auto sync and then slip the audio to match the sticks?
    Christian Hart replied 13 years, 9 months ago 3 Members · 2 Replies
  • Anish Prithviraj
    October 18, 2012 at 3:49 am
    Hi Craig,
    You can slip audio forward and back a frame by using the Option/Alt + , and Option/Alt + . shortcuts (these can be found in the Edit menu).
    Alternatively, you can Right click on the audio/speaker icon on the bottom left of the conform page thumbnail and edit the Audio Sync timecode.
    Anish
  • Christian Hart
    December 3, 2012 at 9:01 pm
    Hi there,
    just to hop on the end of this thread with a related issue
    I’m making dailies with LUTs and and a burn in & syncing audio within Davinci Resolve Lite 9.0.3
    In the case that audio is out of sync (camera/magic slate issue) i have tried slipping the audio manually first in the timeline & all seems fine.
    But then when i add those timelines to the render queue & export them – the audio in the resulting clips is off as if i had not tweaked the sync manually to fix them.
    Quite frustrating. If anyone knows some schoolboy error i may be making i’d love to hear some ideas.
    Best
