audio archiving
Posted by Bill Hamilton on June 28, 2006 at 4:22 pmThis may be a bit off topic,
but I am looking for a way to archive a large music collection, both vinyl and CD. What would be the best format to rip this to? MP3 comes to mind, except that it is a destructive format and I would like to keep the files as untouched as possible for later compression, depending upon the application at the time.Thanks
BillPeter Groom replied 20 years, 2 months ago 4 Members · 7 Replies -
Bouncing Account needs new email address
June 28, 2006 at 5:40 pmThe first question that comes to mind is why would you need to “archive” the CD’s?
They are already on a small high-quality digital long-term medium.
Peter Groom
June 28, 2006 at 8:56 pmHard drives are so cheap nowadays, and cd and dvd storage almost without cost at all, Id go for .wav or .aif as uncompressed.
Additionally, for the cds, if you use a mac and i tunes, then Gracenote will access the entire track listing data from the web automatically and you can save everything from software as you wish with all the information already naming the files.
A real time saver.Peter
Youre right. MP3s are lossy and with mpeg broadcasting etc now a reality, quite a bad idea that early in the chain.
Bill Hamilton
June 28, 2006 at 10:22 pmTrue CD’s are small and high quality, but when there are several hundred, archiving on DVD or a hard drive starts to look appealing. Plus there is the other several hundred vinyl recordings.
Bill
Bill Hamilton
June 28, 2006 at 10:23 pmThanks,
I was leaning to wav files, but wanted to see if I was correct or what options I hadBill
Will Salley
June 29, 2006 at 3:14 amI’ve been working on my collection for about two years.
The CD’s are archived using iTunes and using the Apple Lossless Codec or AAC@320.
Vinyl is done (in painfully real-time) using Audio HiJack Pro,
https://www.rogueamoeba.com/audiohijackpro/
AHP will save the file any Quicktime compatible (including Apple Lossless and 24-bit AIFF). It also saves with tags, uses AU and VST effects, and will automatically start a new file when silence is encountered. Audio Hijack is Mac only.
If you have a Mac, check out MegaSeg for DJ/Radio station playback.
Bill Hamilton
June 29, 2006 at 10:04 amthanks for the info, sadly I’m on the dark side, I run a PC.
Peter Groom
July 1, 2006 at 9:57 amYou should check out itunes. I always thought this was mac only but now believe it runs on pc also now. When you connect to itunes and load a cd, a programme called GRACENOTE can be used to access the track details off the web , and are subsequently automatically added to your archive. Big timesaving trick.
Try it
Peter
