Activity Forums Apple Final Cut Pro Audio appears in timeline, does not play
  • Audio appears in timeline, does not play
    Posted by James Lackleter on October 28, 2013 at 7:37 am
    As I stated above, the audio has stopped being output inside of FCP timeline. Any help, I’m frankly over this program, just trying to get out of it at this point.
    James Lackleter replied 12 years, 10 months ago 3 Members · 9 Replies
  • 9 Replies
  • James Lackleter
    October 28, 2013 at 4:17 pm
    It was a problem with RX3 plug altered clips. I blame final cut, not RX3. Bought Smoke, XMLED out of Final Cut, (luckily that finally works), working fine in Smoke. Good bye, Final Cut.
  • James Lackleter
    October 28, 2013 at 4:35 pm
    Part of an editing software’s responsibility is to work seamlessly between 3rd party software. We’re talking about a program that launched with no XML. I won’t enter this debate, I only used it because an editor, (the one who was fired) started the cut in it. Have fun with your broken toy.
  • James Lackleter
    October 28, 2013 at 5:19 pm
    I don’t want to argue, the plugs work in Smoke and Prem, RX3 is not the only plug with issues in Final Cut. Perhaps I should have left out my disgust for the program in my question. If Final Cut works for you that’s great. Anyway, the problem is solved. And let all know who plan on using the RX3 plug in Final Cut, it’s broken, and you’re better off exporting the audio from RX3 with set adjustments into FC.
  • James Lackleter
    October 28, 2013 at 5:41 pm
    I’m not talking about the Demo, the full version will work initially, as cuts are made it will slowly degrade until you’re adjustments are rendered useless. Andy let’s agree to disagree.
  • James Lackleter
    October 28, 2013 at 6:04 pm
    Okay well I’m glad it works for you, cheers
  • James Ewart
    October 29, 2013 at 1:15 pm
    And it’s never been the case that the makers of the software have to adapt it to work with third party plugins. Never has been, never will be.
    That’s why they are called plugins is it not? The “plug” has to “fit” the software. If it don’t then don’t blame the software maker because they did not make the Plugin.
    Sorry but your logic is somewhat flawed. No fatally flawed.
    http://www.jamesewart.co.uk
  • James Ewart
    October 29, 2013 at 1:53 pm
    You have completely mis read and misunderstood my email. Try reading
  • Chuck Pelini
    October 29, 2013 at 2:08 pm
    [james Lackleter] “Part of an editing software’s responsibility is to work seamlessly between 3rd party software.”
    Correct me if I am wrong here, but isn’t it the responsibility of the company developing the 3rd party software to get things right?
  • James Lackleter
    October 29, 2013 at 10:38 pm
    Plugs that malfunction in FCPX work perfectly fine in other programs. If the plugs didn’t function in Prem or Smoke, MC, I would indeed blame the third party. I really don’t want to stir up a debate on FCPX being bad, there’s a whole thread I found for that.
