Activity Forums Adobe Premiere Pro Audio and Video Problems
  • Audio and Video Problems
    Posted by Jake Penta on August 31, 2010 at 11:58 pm
    Hey, I’m relatively new to Premiere Pro – Still CS4 -, had Final Cut, but switched over because of familiarness with After Effects
    So I was wondering, I’ve shot an Action Sequence with my iPhone 4 to test the HD video quality
    30.00 fps
    1280×720
    16 bit audio
    I press CMD-I in finder to check the codecs and it reads, H.264, AAC
    Now, when I start a new sequence with the HDV 720p 30 codec, and render out the beginning completely I get blurry and sometimes slightly skipping video. Keep in mind that the video has no problems in the preview window ( the one where you can select in’s and out’s ) and it continues to do this. I have tried changing the video settings but nothing changes.
    If I pause the video and go to the same frame on both the preview window and the “canvas” the frames look the same
    Also, if I was to want to grab just the audio from a clip ( a lazy ADR replacement ) how would I do that?
    Thanks so much in advance!
    Jake Penta replied 16 years ago 1 Member · 0 Replies
  • 0 Replies
