Activity Forums Adobe After Effects audio and video not synchronized when rendered (fine in RAM preview)
  • audio and video not synchronized when rendered (fine in RAM preview)
    Posted by James Harris on December 28, 2012 at 2:52 am
    When I RAM preview my composition, everything is lined up and sound matches the video exactly, but when I render the audio is playing slightly earlier than video, but the I am rendering a motion graphics shot with very precise timing for sound (impact,swiches…)
    All my used sound are .WAV and all my footage is .EXR rendered from Maya so no compressed footage or sound used.
    The audio sample rate of my project us 48 Kbps (AE default) – 29.97 FPS – 32 Bit per channel mode.
    I am rendering an uncompressed QuickTime out of AE with uncompressed Audio checked( 48 Kbps, 32bit) and then I export all this in QuiickTimePro in a H264 compression format (AAC for Audio) since rendering compressed QuickTimes from AE is not advised and my QuickTime bite rate is not exceeding the 14 Mb/s and playing FPS is stable around 30.
    I also tried using different bite rates but nothing works. Any ideas?
    James Harris replied 13 years, 9 months ago 3 Members · 6 Replies
  • Todd Kopriva
    December 28, 2012 at 7:24 am
    [same answer as here]
    Why are you using H.264 in a QuickTime container? That is a rather buggy exporter. Try something (anything) else to see if this is the cause of your problem.
    But, more important ultimately, you need to choose a better export format. Start here for that:
    https://forums.adobe.com/thread/729526
    After Effects team blog
  • Vishesh Arora
    December 28, 2012 at 7:58 am
    roy
    You can use Photo – JPEG Video Codec with MOV as it will compress around 70% and gives a good quality. If you want lossless then go for PNG Video Codec.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • James Harris
    December 28, 2012 at 2:48 pm
    I tried PhotoJPEG, JPEG 2000, PNG, ANIMATION all with same problem (all compressions generated in QuickTime pro)
    I even have the problem when I render a straight uncompressed quicktime out of after effects.
    But when I open my H264 in WindowsMediaPlayer or in AE, everything seems fine, it seems the problem comes from quicktime pro (definitly not from my hard drive speed or hardware since I have a modern gear). Really dont get it, how come WMP perform better than QUickTime and if the biterate is quite low then what is causing this in my quicktime pro player?
  • James Harris
    December 28, 2012 at 3:24 pm
    PNG, photojepeg gave the same problem
  • James Harris
    December 28, 2012 at 4:01 pm
  • James Harris
    December 28, 2012 at 4:48 pm
    Relax, I did read your link.
    It didn’t help in solving the problem since the huge file size is not the issue here, I am having the same audio/video lag problem when playbacking a compressed footage with low bite rate.
