Activity Forums Apple Final Cut Pro Legacy audio and video from diferent sources
  • Liam Stephens
    February 17, 2006 at 9:09 pm
    Its a tricky question unless I actually know what u are going to be cutting. I have to do syncing with various segments which have differnet takes. I usually make a sequence for each segment. I put all the takes from the seqment with multiple cameras and audio sources and sync them up. I keep these sequences as my “sync sequences” which i can always go back to if i go out of sync or make an error. I pick the best takes and put them in a new sequence which is my “final sequence” and begin to cut away. Everything is in sync and ready to cut with a synced backup within the project. Hope that helps.
  • Sergio Deustua
    February 21, 2006 at 10:25 am
    Thanks.
    Have you ever tried to export a “sync secuence” as a quick time movie and then import that as an audio/video clip? This can be a good solution?
