Activity › Forums › Apple Final Cut Pro Legacy › Audio and Color Correction issues
  • Audio and Color Correction issues
    Posted by Derek Justin on August 23, 2012 at 3:09 pm
    This might be improper, but I am experiencing two separate issues that i thought I would condense into one post. I have worked with FCp for years now, but not seen these yet. They are most likely an easy fix.
    Problem #1
    Over the past few days, I have experienced the audio just vanishing. Nothing is changed in the timeline and nothing was done to trigger. I can still see the audio clips on the timeline, but there is no sound and no bars in the meters either. They just disappear. Nothing When I close and restart the program, the audio and levels are restored.
    Problem #2
    When Color Correcting, I add the 3-way color correction filter to the clip. I make the corrections and the clip in both preview and timeline shows the corrections accurate, but unrendered.
    As soon as I render, it reverts back, or at least to a different state than that which I corrected it to.
    This has me baffled.
    Thanks for any help.
    I can offer any additional info if needed.
    -derek
    Derek Justin replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
