Activity Forums Adobe Premiere Pro Audio adjustments
  • Audio adjustments
    Posted by Alex Rod on July 16, 2013 at 1:43 pm
    So the audio volume levels don’t seem to be proportionate like in FPC.
    What I mean is, I lower the volume of an audio track and it still plays very high. The difference between 16db and 28db is very little. Then it seems to be not proportionally low/high according to the adjustments
    Peter Garaway replied 13 years, 2 months ago 3 Members · 2 Replies
  • Kris Merkel
    July 16, 2013 at 2:55 pm
    Not sure what you are saying. The difference between 16db and 26db is always the same. It is a measurement and not subjective. Now if you are just talking about the difference of scale between the audio adjustment levels in FCP and PrPro then you would have a question. Use the meters or you can adjust using the faders in the clip mixer if you want a better visual reference.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Peter Garaway
    July 16, 2013 at 3:10 pm
    What Kris said it correct. Also if your in Premiere Pro CC the new LoudnessRader is a great tool to monitor your levels. See more info here: https://www.tcelectronic.com/adobe-loudnessradar/
    If your using CS6 Premium Beat wrote a nice blog on the new audio meters in CS6. https://www.premiumbeat.com/blog/audio-meters-premiere-pro/
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
