Activity Forums DSLR Video audio
  • audio
    Posted by Aaron Lloyd on July 28, 2019 at 1:12 am
    I have the H4N, a Sennheiser lav, and a Rode NTG 3. Can I record using both mics to have 2 separate tracks of an interview on the Zoom? If so,what settings do i use> I am recording an interview for a doc.
    Reply
    Steve Crow replied 7 years, 1 month ago 2 Members · 1 Reply
  • Steve Crow
    July 29, 2019 at 12:32 am
    The short answer is yes. Research 4 Channel Mode and MTR (multi track recording)
    https://helpwiki.evergreen.edu/wiki/index.php/Zoom_H4n_Audio_Recorder_Operating_Guide
    4CH Mode – Simultaneously uses the H4n’s built in stereo mic and inputs [1] and [2]. Recording volumes are controlled by source. Before using the REC LEVEL (+) or (-) button, you must first choose which source you wish to modify the volume for by pressing the corresponding input select button.
    NOTE: The REC LEVEL (+) or (-) button should not be confused with the VOLUME (+) or (-) button found on the other side of the recorder. The VOLUME button controls the levels of audio output (the speakers or headphones).
    MTR Mode – MTR mode is designed to record onto 4 separate tracks. Each of the tracks can be recorded and modified independently from any of the others. Additionally, tracks 1 & 2 or 3 & 4 can be recorded together. Each track can record from any of the input sources. To begin recording in MTR mode:
    Choose which track (or pair of tracks) you would like to record to.
    Choose the inputs you would like to record onto that track.
    Steve Crow
