Activity Forums VEGAS Pro Audio
  • Audio
    Posted by Belinda Edwards on December 21, 2007 at 4:42 pm
    I was explaining to someone that I just did a video and played the burned video on three different players. I normally in Vegas, choose to render to MainConcept 2, both the audio & video combined. I have never had a problem doing this. I upgraded to Vegas 8, so that is what I am using now, and using Encore to author dvd. On the one dvd player, I was getting music during the menu, but during the 3 videos that are also on the dvd, there was no audio heard. When I pressed the audio button on the dvd player remote, it said the following about the audio: during the menu it said “Dolby audio”, during the 3 videos it said “mgeg2 audio stream. The person I was telling this to told me to never render audio to mpeg2, and sent me the following message:
    I always prefer elementary streams as opposed to a single multiplexed file.
    If you don’t want to do separate elementary audio and video streams, then see if you can tweak the template in Vegas to allow PCM or DD audio.
    Is this possible in Vegas? If so, how? The dvd did work fine on 2 out of 3 players in the house, so would you go on doing the rendering through MainConcept Mgeg2 on both video/audio, or go another route?
    Edward Troxel replied 18 years, 8 months ago 2 Members · 1 Reply
  • Edward Troxel
    December 21, 2007 at 4:55 pm
    You should render to two files as he’s suggesting. Render the video to MPEG2 without audio. Then render to audio to AC3 or WAV and give him both files.
    Edward Troxel
    JETDV Scripts
