  • Posted by Sheree Day on June 23, 2012 at 5:07 am
    HI,
    Just new to Premier Pro CS6, so would like some help.
    How do I unlink two audio tracks? I have used a camera that records on two channels, and when I put the vision on the timeline with audio I get both tracks, but I need to delete one some times, so how do I unlink them so I can delete only one when I need to?
    Also, I can adjust the audio volume on an entire clip on the timeline, but I haven’t figured out how to adjust the audio level on a clip when I need to increase or decrease at multiple points.
    Thanks for your assistance in advance.
    Ann Bens replied 14 years, 3 months ago 2 Members · 1 Reply
  • Ann Bens
    June 25, 2012 at 10:14 pm
    To unlink: rightclick on clip and select unlink.
    First make sure Show clip keyframes is on in the Track Header.
    Hold ctrl and put keyframes on the yellow line of the audio.
    Now you can adjust the audio between the keyframes or pull the keyframes up down left or right.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
