Activity Forums Adobe Premiere Pro Audio 1&2 the same as 3&4?
  • Audio 1&2 the same as 3&4?
    Posted by Dickij on May 19, 2006 at 9:37 am
    I’m fairly new to PPro2 and I have a question…
    I need to layoff a job to DigiBeta with the 4 audio channels; 3 & 4 need to be the same music as on 1 & 2. How can I make PPro 2 output to all 4 channels? I tried making a copy of the stereo music track on the timeline but I couldn’t patch that to 3 & 4 while having the the original output to 1 & 2.
    Anyone got any tips?
    Jamie
    Dickij replied 20 years, 4 months ago 3 Members · 5 Replies
  • Chris1621
    May 19, 2006 at 11:17 am
    I’m not sure if Premiere can output all 4 channels at once. The alternative would be to do 2 passes – one for tracks 1 and 2 and then do a second pass and insert audio for 3 and 4.
  • Chris1621
    May 19, 2006 at 11:18 am
    Just to add, thats assuming you have deck-control of course…
  • Dickij
    May 19, 2006 at 1:28 pm
    That’s a bit pants!
    It shouldn’t be a problem, as someone just steered me to Menu 804 on the DigiBeta which is just what I need!
    Thanks for the response anyway. 🙂
    Jamie
  • Steven L. gotz
    May 19, 2006 at 3:52 pm
    dickij,
    Please explain that menu option if you would. It sounds like something someone else will need to know. I ran into a question like that recently. Also, please explain the meaning of “That’s a bit pants! “
    Steven
    https://www.stevengotz.com
  • Dickij
    May 19, 2006 at 7:04 pm
    Well… on a Beta SP machine you have a switch so you can opt to have the input of Ch 3 & 4 taken from the Ch 1 & 2 inputs. On the DigiBeta the same thing is in the menu 804. You can either have Ch 3 and/ or Ch4 take their inputs from the Ch 1 and 2 inputs, or take their input from the front panel 3 & 4 switches (analogue/SIF/AES).
    ‘That’s pants’ means ‘I’m not very impressed to find this feature missing’! :). If I wanted something different on 3 & 4, I’d be stuck. I feel sure there must be a way to get all four channels to tape? I started playing with 5.1 but didn’t get anywhere!
    Jamie
