Activity Forums Storage & Archiving Atto R680
  • Posted by Jim Curtis on October 19, 2010 at 2:32 am
    I’m currently running an Enhance E8 MS with a HPT RR3340. I simply don’t trust the HPT card, and due to a horrendous customer service experience with them when my last card went bad, I want to go with an ATTO.
    ATTO just brought out the R680, and I’m wondering if my Enhance Box will work with it.
    The spex on the E8 web site call for a 3 Gb/s HBA and SATA or SAS drives. But, the spex were written before any 6 Gb/s devices were even available. (I’d also like to use 2TB 6 Gb/s SAS drives, but those weren’t available either, and they are now).
    I wrote to an engineer at Enhance-Technology, and since they haven’t tested it yet, I don’t think he wants to even speculate as to whether it will work. He did write that “it might work.”
    I’m not a RAID genius by any means. The Enhance engineer mentioned a “3 Gb/s backplane” in his reply.
    That didn’t mean anything to me, so I read up on backplanes. It appears there are two different types: one just functions as a wire replacement (“straight through”), in which case the enclosure should be agnostic to 3 or 6 Gb/s devices, and the other is a “multiplier backplane,” which I suppose involves a chipset.
    I guess what I’m asking is if I’m going to need to buy a new drive enclosure if I want to use the new ATTO R680.
    I think I know the answer, but I wanted to probe the brain trust.
    Jim Curtis
    jamesphilipcurtis.com
    MacPro (Harpertown-Early 2008) 2×4 3GHz; 32G RAM all the same brand; Dual Boot: 10.6.3 & 10.5.8; QT 7.6.6; FCS3; Kona LHi in PCI slot 3 (7.5.1); Primary display: 30″ ACD; Secondary: HP LP2480zx DreamColor (A) via AJA HDP2 SDI to HDMI converter and (B) DVI from MacPro.
    Chad Gilmour replied 14 years, 8 months ago 7 Members · 19 Replies
  • 19 Replies
  • Bob Zelin
    October 19, 2010 at 3:46 am
    you are wasting your money. You have 3 Gig drives, with a 3 Gig enclosure. You want to future proof, but guess what – YOU CAN’T. Buy the wonderful ATTO R380, and you will have exactly what you want – a working system. You will get SLOWER PERFORMANCE with the ATTO R680 and your current system.
    Unless you are willing to spend the money on a 6 Gig chassis that has SSD or SAS drives in it, you are WASTING YOUR MONEY, and will be disappointed.
    bob Zelin
  • Jim Curtis
    October 19, 2010 at 2:29 pm
    Thanks, Bob. Good to know.
    So then, are there any 6Gb/s 8-drive enclosures you’d recommend for placement in the edit room – that are quiet like the Enhance Box / ProAvio?
    I scoped the web, and 2TB 6Gb/s SAS drives (ie Seagate Constellation) are shipping for around $300.
    Jim
    Jim Curtis
  • Bob Zelin
    October 20, 2010 at 2:40 am
    I have not tested these drives, so I cannot tell you how they work.
    Everything you do yourself is a science project. Sometimes it works, sometimes it doesn’t.
    Bob Zelin
  • Jim Curtis
    October 20, 2010 at 7:04 pm
    I already bought the card. It was only $119 more than the R380, so I can tolerate the slower speeds until Enhance comes out with either a 6G backplane update kit for my E8, or I have to buy a new chassis.
    I installed the R680 for about a week. It worked at around 480 Mb/s with my SATA drives for about five days, then started hiccuping and telling me a drive was bad and then started giving me repeated kernel panics. I yanked it and re-installed the previously installed HPT RR3340, which is working, and reporting good drive health all around. From this, I concluded the R680 was bad, and told the VAR who sold it to me so. The next morning, I had a new card from ATTO on my porch. This confirms the fabulous customer service I read about here (and also Evan at BackupWorks).
    But then, I got to thinking whether the card was just incompatible with my E8, hence my initial post.
    Since then, my VAR spoke to ATTO, and they told him to tell me that the R680 will work where a R380 would, but at the slower speed. It could be a couple more weeks before I have enough downtime to swap cards again.
    Enhance told me they’re getting 1 Gb/s read/writes in their E800 3G chassis with SAS drives and a 3G HPT RR3340 HBA. They put this data on their site, so I assume some level of confidence that they’d work for customers. They also told me they are testing the R680 with their “JBOD products,” and aren’t quite ready to qualify it officially.
    Jim Curtis
  • Bob Zelin
    October 21, 2010 at 1:28 am
    I told you so.
    I am glad that you posted your results.
    SAS drives and SSD drives are not SATA drives, and 3 Gig chassis are not 6 Gig chassis.
    The ATTO R680 will be the king when the rest of the pieces of the puzzle come out. Everyone wants to “future proof” – you can’t future proof. And once it is stable, the next thing will come out.
    Bob Zelin
  • Jim Curtis
    November 2, 2010 at 3:31 pm
    I have new results to post:
    I bought (9) 2TB Seagate Constellation SAS drives and installed 8 of them in my Enhance E8 MS chassis (It has a 3Gb backplane.).* I installed the ATTO R680. After setting up a RAID 5 and making (4) 3.5 TB partitions, I ran AJA System Test on all four partitions.
    * [One drive arrived defective, and is on it’s way back to Amazon for a free replacement, including two-way shipping. I’ve learned it’s advisable to have a spare drive on hand. When running a degraded RAID 5, one is on pins and needles until a replacement is inserted and the rebuild is complete.]
    I’m getting an average of 600-700 Mb/sec reads on most of the AJA tests – and over 1000 on some of them, and an average of 600 Mb/s writes on all partitions.
    It’s an improvement of around 200 Mb/s from my 1 TB SATA drives and the RR3340 card, where I was getting in the 400 Mb/s range for reads & writes.
    I loaded up a project with 2K 24FPS ProRes HQ source files (transcoded from RED RAW). The timeline scrolls like butter, and I am getting two PIP real time streams with no frames dropped. With three PIP streams, sequences play at full resolution, but the frame rate drops to what looks like 12 fps (This is on a 2008 octo Mac Pro.).
    I’m aware I have a bottleneck here: my 3Gb chassis. So, I’m hoping to see even better performance with a 6 Gb chassis, when a reasonably priced and quiet one comes out. If anybody hears of one, please pass that info along.
    Until then, I’m satisfied with a roughly 50% increase in I/O, a better than doubling of storage capacity, and most of all, the peace of mind that comes with using a controller from a top-tier company.
    Jim Curtis
  • Jim Curtis
    November 3, 2010 at 5:41 pm
    After doing some more web surfing, I’ve discovered two 8-drive desktop (tower) enclosures specced for 6Gbs:
    Areca ARC-8040 ($2090 and $2250 from Acme and NewEgg, respectively),
    and the SANS DIGITAL TowerRAID TR8XP ($680 from NewEgg).
    The Areca site is demonstrating (AJA System Test) over 1Gb/s read & writes using SAS drives in RAID 5.
    Dell has a rack-mount 6Gbs enclosure, but no desktop tower. Other than that 6Bbs backplanes seem to be few and far between at this point. Curious, considering the plethora of 6Gbs HBAs that are showing up.
    Jim Curtis
  • Hai au Bui
    November 10, 2010 at 4:39 am
    https://macperformanceguide.com/HardwareRAID-iStoragePro.html
    Check this link for a SAS enclosure that will run fine with your ATTO card.
  • Jim Curtis
    November 10, 2010 at 6:23 pm
    I got excited for a moment, until I found nothing in the review or on the manufacturer’s site about compatibility with 6Gb/s drives. This line appears to be for 3Gb/s compatibility.
    Oh well, thanks for the link, though. I’ll keep an eye on this company for a new 6Gb/s product. The design of their products looks sturdy, I love the 3-year warranty, and it’s designed to be visually compatible with the MacPro.
    In the meantime, I made some more inroads on what is available and 6GB/s. I’ve learned the Areca ARC-8040 has RAID control built into the chassis firmware, and so that’s some overkill for those using full-featured RAID cards like the ATTO R380 and R680. I learned Areca has a “dummy JBOD” box as well, that would be better suited for one of these HBAs: the ARC-4036. So, what I’d like and could use exists, but I can’t find anybody selling it!
    Even if I could, I’d be more comfortable buying from a US firm, simply because of east access to warranty service, if needed. Because the Arecas are from Taiwan, and have such scant US presence via VARs, I’m hesitating to be that much of a pioneer. I’m fairly confident that a plethora of 6Gb/s chassis will be fairly commonplace around early 2011.
    Jim Curtis
    MacPro (Harpertown-Early 2008) 2×4 3GHz; 32G RAM all the same brand; 10.6.3; QT 7.6.6; FCS3; Kona LHi in PCI slot 3 (8.0.1); Primary display: 30″ ACD; Secondary: HP LP2480zx DreamColor (A) via AJA HDP2 SDI to HDMI converter and (B) DVI from MacPro.
  • Hai au Bui
    November 10, 2010 at 10:16 pm
    I’m sorry for giving out wrong hopes. I thought it was a 6Gb/s case. I’m pretty sure I about a 6Gb/s on AMUG or Barefeats. I’ll try to find it again.
    I’m waiting for my R680 with CacheAssure to come in soon.
