ATTO NT11 10GB Cards
Hi Just a quick question,
Purchased two Atto NT11 10gb cards, Installed them into Slot 2 in two Mac Pro towers,verified in the mac config that they are in 8x slots and installed the current atto drivers for mac osx 10.8.4.
I have both of them running into a netgear 10gb M7100 switch via cat 6e cables only around 10ft.
In the switch i can see that it sees the connections as 10gbe.
When i look in the networking panel on the Macs, it sees the card in the left hand window and shows me the PCI card in the PCI card slot.
I assign them both a static IP address.
However when i go into the Advanced Tab and Hardware, and try to configure the settings manually i do not see 10gbe under speed as an option, only 100baseTX and 1000baseT.
Am i missing something? i thought the 10gb option speed would show up here?
I tried a basic copy from one mac to the other mac, and it defiantly didn’t seem like 10gb speeds.
Do i need to install Iperf and verify this?
All i am looking to eventually do is move six of our macs onto this switch as well as a basic Linux file storage system to allow the moving of files around a little quicker than the current setup on 1000 ethernet.thanks
Brian
