Activity Forums Storage & Archiving ATTO Celerity HBAs on QLogic switches
  • ATTO Celerity HBAs on QLogic switches
    Posted by Ben Cheng on February 5, 2007 at 11:36 am
    I like to seek advice on connecting ATTO 4Gb Celerity HBAs, (on Mac Pro with Mac OS X 10.4.8 and ATTO Celerity 3.0 driver) with QLogic FC switches, both 4Gb 5600 and 2Gb 5200.
    Do we have to configure the FC switches port properties e.g Port Speed, StreamGuard and Device Scan?
    Cheers,
    Ben Cheng
    Shane Sokolosky replied 19 years, 6 months ago 2 Members · 3 Replies
  • Shane Sokolosky
    February 5, 2007 at 7:07 pm
    Hello Ben,
    If your using both 2Gb storage and 4Gb storage you’ll want to keep the speed at Automatic, although if your using it with only 4Gb fibre channel devices then I’d hard set it to 4Gb, as for the IO stream gaurd, you’ll need to set it to on for all ports that initiators (HBA / Computers) are pluged into and turn it off on all the ports that the storage is pluged into.
    Shane Sokolosky
    Circuit Access
    Email – heysomthin@aol.com
    Phone – (714) 599-1611
  • Ben Cheng
    February 6, 2007 at 3:28 pm
    Hi Shane,
    Thanks for your advice.
    Here’s what I did,
    I/O Stream Guard (for XServe RAID) – Disable
    I/O Stream Guard (for ATTO HBA) – Enable
    Device Scan (for XServe RAID) – Enable
    Device Scan (for ATTO HBA) – Disable
    Port Type (for XServe RAID) – F
    Port Type (for ATTO HBA) – Auto
    So far, testing went fine.
    I like to check if the XServe RAID driver 1.0 is required on Mac OS X 10.4.8?
    Hope you can advice me its function as well.
    Cheers
    Ben
  • Shane Sokolosky
    February 6, 2007 at 6:32 pm
    Actually it depends on the version of OS you installed originally, but if it’s in software update then go for it, the one thing you’ll want to watch out for on the X Serve RAID that can lead to drop frames is not allowing host cache flushing
    here’s an article about it from apple.
    https://docs.info.apple.com/article.html?artnum=302780
    Shane Sokolosky
    Circuit Access
