Activity Forums VEGAS Pro Attn John Rofrano – Vasst Ulimate S Pro 4.1 and SVP10
  • Attn John Rofrano – Vasst Ulimate S Pro 4.1 and SVP10
    Posted by Nigel O’neill on October 13, 2010 at 3:28 am
    John
    Is there going to be a complementary or corresponding upgrade for Ultimate S Pro 4.1 users for Sony Vegas Pro 10?
    Short of trying it out myself, has Vasst done integration testing with SVP 10 that you are able to share the results of?
    Thanks in advance
    Intel i920, 12GB RAM, ASUS P6T, Vegas Pro 9 (X64), Vista x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S 4.1
    Kornel Scherrer replied 15 years, 10 months ago 3 Members · 4 Replies
  • John Rofrano
    October 13, 2010 at 5:15 am
    Ultimate S Pro 4.1 already works with Vegas Pro 10 and has been tested by VASST. So does Ultimate S Lite, GearShift, infinitiCAM, Mayhem, etc. They are all working in Vegas Pro 10 and all of the installers have been updated yesterday (Oct 11) to recognize VP10 if that’s the only version you have installed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kornel Scherrer
    October 16, 2010 at 7:56 pm
    Hi John,
    I have installed Ultimate S Pro 4.1.3 in Vegas Pro 10 on Windows 7.
    Everything works as expected when running SVP 10 as Administrator.
    However, when running SVP 10 as a standard user, the extension is not found: View.Extensions is empty list.
    How can I get Ultimate S Pro working also in standard user mode?
    Any help is appreciated.
  • John Rofrano
    October 17, 2010 at 5:20 pm
    [Kornel Scherrer] “Everything works as expected when running SVP 10 as Administrator. However, when running SVP 10 as a standard user, the extension is not found: View.Extensions is empty list. How can I get Ultimate S Pro working also in standard user mode?”
    Ultimate S Pro is license to a single user. It is not designed to be shared across multiple users nor does the license agreement allow it. We assume that the user has administrative privileges to install. If the user does not have administrative privileges to install you can make the standard user an administrator so that you can install Ultimate S Pro as the standard user and then make them a regular user again after the install is complete. It does not require administrative privileges to run so it should work fine after the installation.
    ~jr
  • Kornel Scherrer
    October 18, 2010 at 6:03 pm
    The question was not related to multi-user at all.
    As Microsoft recommends, I have a standard user account separated from an account with administrator privileges.
    Anyway, the workaround that you suggested is working.
    I have temporarily added my standard user account to the Administrators group, have installed Ultimate S Pro again.
    Then removed my std user account from Administrators.
    Everything works as intended. Thank you!
    It would be very nice, if you had documented this procedure in the readme file.
