Activity Forums Maxon Cinema 4D Attaching Spline Points to a Sphere
  • Attaching Spline Points to a Sphere
    Posted by Dan Fassnacht on May 14, 2012 at 4:43 pm
    Hello all,
    Basically I’m trying to have an arc connect to the surface of two points on a globe. I’ve got to nulls on the surface of the globe using a constraint tag (one usa, the other paris) I basically want to be able to draw a spline that will connect those two points. I’ve tried some Xpresso solutions but I’m fairly new to Xpresso and can’t really get it to work.
    If anyone has any suggestions that would be greatly appreciated. If you can provide step by step that would greatly increase the outcome of me not messing it up somehow.
    Best,
    Dan
    Greg Burrus replied 14 years, 4 months ago 2 Members · 1 Reply
  • Greg Burrus
    May 16, 2012 at 1:57 pm
    You could do this with a tracer object that connects two points with each other. Then add some in between points for a smooth curve. You could connect all points to all ways have a line showing then use a sweep nurb to draw the line. You could just draw the spline too. I’ve attached a quick file as an example.
    4153_splineconnect.c4d.zip
    Robert Leger had a tutorial on something similar to this using Xpresso on his old site I believe which should be on his vimeo channel. And on c4d tools there is a preset that connects two points for an electric ray. You could open that up and figure out something based on that.
    Hope this helps
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
