Activity Forums Adobe After Effects Expressions Attaching Particular,Camera POI,Layer’s Position.
  • Attaching Particular,Camera POI,Layer’s Position.
    Posted by Eran Solomon on January 12, 2009 at 2:33 pm
    Hey everyone,
    Before I start I’ll state the info.
    Im using Trapcode’s Horizon(awsome), particular, and one small layer.
    My attention is to make the small layer fly around in the comp, attach a point emitter to it (smoke?) and also make the camera POI follow the emitter point.
    Can anyone help me with that?
    So I actually need the Particular emitter attached to the small layer’s Position, and the camera’s POI attached to the emitter points (or the small layer’s position).
    I hope I was..understandable. 🙂
    Thanks in advance !
    Dan Ebberts replied 17 years, 8 months ago 2 Members · 1 Reply
  • Dan Ebberts
    January 12, 2009 at 3:15 pm
    An expression like this should work for the emitter Position XY and the POI:
    thisComp.layer(“small layer”).transform.position
    and like this for the emitter Position Z:
    thisComp.layer(“small layer”).transform.position[2]
    If your small layer has a parent, you’d need to use this form instead:
    L = thisComp.layer(“small layer”);
    L.toWorld(L.anchorPoint)
    and
    L.toWorld(L.anchorPoint)[2]
    Dan
