Activity Forums Apple Motion attaching objects to camera?
  • attaching objects to camera?
    Posted by Kyle Traynor on June 24, 2008 at 12:43 am
    I cant seem to find a way to attach and object (text, image, ect) to the camera. Im attempting to animate my camera to move through several different objects but I want to keep a constant background. I have noticed the “face camera” feature on some of the objects in the library but it doesnt seem to work. Im sure this is possible and I have done this before using Maya but I just cant seem to find out how to attach anything to a camera. Please help, Thank you
    Kyle Traynor replied 18 years, 3 months ago 2 Members · 2 Replies
  • Doyle Rockwell
    June 24, 2008 at 1:55 am
    Howdy,
    You can attach an object (or group) to the camera using a Match Move behavior. However, if you just want certain objects to ignore the camera (i.e. always be in the foreground or background, however much the camera moves), just put them in a 2D group at the root level of your project. For example, if you had a Layers List like this:
    -2D Group
    – Foreground object 1
    – Foreground object 2
    -3D Group
    – Some object 1
    – Some object 2
    -2D Group
    – Background object 1
    – Background object 2
    The contents of the top 2D group will always be on top and will ignore any camera movement. The bottom 2D group will always be behind everything and will also ignore the camera movement.
  • Kyle Traynor
    June 24, 2008 at 8:42 pm
    Thanks Jim that sounds much less complicated then actually attaching the image to the camera. Greatly appreciated.
    Kyle Traynor
    Envision Edit
    traynor.edit@gmail.com
