Activity Forums Maxon Cinema 4D attaching object to the ends of each single hair
  • attaching object to the ends of each single hair
    Posted by Peter Egermann on May 21, 2009 at 3:35 pm
    hi,
    is there a way to attach copies of an object to the ends of each single hair in a hair object? i know how to connect an object to the end of a spline using xpresso, so i told the hair object to generate splines but i have no idea what to do next.
    thanks for any help
    peter
    Adam Trachtenberg replied 17 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 22, 2009 at 10:39 pm
    You can use the hair object’s generate>type>instance setting to attach objects to hairs.
