attaching layers together with rubber bands under water
I know enough about expressions to know that this is possible, but I don’t know how.
I want to link 5 layers to 1 other layer. I want to use the position attribute.
When I move the 1 layer’s x, y or z position, the other 5 layers should follow with physics, as if attached with ‘rubber bands under water’.
Example:
If I move the leader layer to the right, the other 5 layers don’t move right away, they are a bit delayed. When they do start to follow, they react as if attached with elastic bands.
When the leader layer stops, the 5 layers ease into their places.I’ve seen things like this done in Flash with things that follow the mouse.
Where do I start?
Thanks.
