Activity Forums Adobe After Effects Expressions Attaching an inpoint of a layer to an outpoint of another layer
  • Attaching an inpoint of a layer to an outpoint of another layer
    Posted by Detlef Maerz on February 19, 2021 at 8:24 am
    Hi guys! Is it possible to attach an inpoint of a layer to an outpoint of another layer via using expressions or scripts? The first Layer is a VA layer, wich shall have a variable duration , the second layer is a composition with a fix duration. This two levels should always follow each other on the timeline without a gap or overlapping.
    Detlef Maerz replied 5 years, 6 months ago 2 Members · 2 Replies
  • Trent Armstrong
    February 19, 2021 at 3:34 pm
    Hi, Detlef!
    I think you can do this with an expression on the time remapping of the second layer.
    TIME-REMAP EXPRESSION:
    theStart = thisComp.layer(“VA layer”).outPoint;
    theEnd = theStart + key(2).time;
    t = linear(time, theStart, theEnd, key(1).value, key(2).value – .01)
    OPACITY EXPRESSION:
    if (time >= thisComp.layer(“VA layer”).outPoint) {100} else {0}
    (I have trouble sometimes with the copy and paste of the expressions periodically. If it doesn’t work for you, just type the expression in manually.)
  • Detlef Maerz
    February 21, 2021 at 7:49 am
    Hi Trent, wasn’t thinking about time-remap. Good Idea! Thanks a lot!
