Activity › Forums › Adobe After Effects › attach track to mask
  • attach track to mask
    Posted by Adam Taylor on September 21, 2007 at 12:28 pm
    I’ve got an urgent job an i’ve found a problem i don’t know how to get around.
    The shot is handheld, so i have used a tracker to get a motion reference. I want to apply a mask to allow me to mask out part of the shot, and i want the mask to matchmove the shot.
    I can’t work this out and its driving me nuts!
    any suggestions
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
    Adam Taylor replied 19 years ago 3 Members · 3 Replies
  • Steve Roberts
    September 21, 2007 at 1:00 pm
    Mask vertices are accessible through expressions in CS3, so if you track some points, you can then pickwhip their position to the mask vertices. (I haven’t tried it yet)
    Third-party solutions such as Sihouette Roto do it directly, apparently.
  • Mike Clasby
    September 21, 2007 at 4:58 pm
    There are two scripts that do what you want.
    1) Here’s a Script. It works as good as the track you get:
    https://del.icio.us/escruz/Rotoscope
    Download, then copy/move the jsx file RotAE.jsx to AE’s Script Folder, then open AE.
    Select the layer with the Mask, File>Run Script>RotAE.jsx. Then select the Mask again, and in the control panel that popped up, hit “Apply Tracker”, and you’ll have as many track points as you have mask vertices.
    Run you Motion Track. The mask will be as good as the motion track so you may have to adjust points by frame like you mentioned in Aharon’s tut.
    Now twirl down the layer, select the Tracker 1 (above the mask points) and also select the Mask, then up in the Script’s Control panel, click ” Apply Mask”. You should be good to go.
    You can still move individual mask points if the track wasn’t great, or adjust the bezier handles as needed, as the script just set mask Shape keyframes at each frame.
    2) There is another script, “rotoTool”, I haven’t really used it yet, but his stuff is great. Here’s the script:
    https://www.nabscripts.com/Downloads/downloads_en_3.php?id=1
    His site is French and some of the scripts a low on translation, but the Help “?” in the script panel for this particular script is English, and looks very straightforward, yet versatile. It converts tracks to masks, or reverses tat converting masks to tracks.
    Lots of other interesting scripts there too.
  • Adam Taylor
    September 22, 2007 at 9:34 pm
    in the end i manually tracked it as it was such a rush job.
    I’ll look into those scripts for future though..
    thanks
    adam
