Activity Forums Adobe After Effects Attach Point Stops Tracking
  • Attach Point Stops Tracking
    Posted by Nick Berrisford on July 8, 2005 at 7:31 pm
    I am using the tracker in 6.5. I haven’t really used the tracker much since I upgraded from 6.0 awhile back, so I don’t know if this problem is new to 6.5 or not, but I don’t recall having it with the tracker in 6.0.
    Basically I am tracking something which moves off screen but I want the tracking info to “follow” it off screen and continue that direction. I have done the trick where you make a biiger comp layer so it will be able to track past the edges of my main comp and I have set the extrapolate motion parameters so it does simulate tracking past the edge of the comp frame. The tracker windows work fine – the motion follows just like I want it to. The problem is that the attach point cross hair stops even though the tracker keeps going, so obviously whatever I attach to it stops as well. I don’t remeber that occuring in the past, or if it did, I sure don’t remeber what I did to correct it. Is there a new setting for 6.5 that affects this? I do notice that the layout of the options etc. is different in 6.5, so I am wondering if there is something new which is creating this problem.
    Thanks in advance to anyone who can help me either kick start my brain and figure this out or explain what is wrong and how to resolve it.
    -Nick Berrisford
    Nick Berrisford replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
