Activity › Forums › Maxon Cinema 4D › Attach multiple spline points to cloned objects
  • Attach multiple spline points to cloned objects
    Posted by Ashish Gupta on June 7, 2013 at 12:27 pm
    https://vimeo.com/45253526
    I am trying to create the effect at 00:15 .. where the different icons come out and they are all connected with string like splines ..
    I created the icons with cloner and applied a random effector for random position .. then i used a tracer to create splines attaching all objects from center .. i made the tracer editable and put a spline dynamics tag..
    Now i need to figure out a way to connect different points on this spline to the clones …
    Here’s my scene file so far ..
    6118_splinepointstoclones.rar.zip
    Also if anyone knows a better way to achieve this effect please let me know ..
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Adam Trachtenberg replied 13 years, 3 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    June 7, 2013 at 3:41 pm
    Select all of the splines’ end points, then click the spline dynamics tag, go to the properties tab, and click the Set button next to the word “Fixed”.
  • Ashish Gupta
    June 7, 2013 at 3:48 pm
    I did that to the points in the center but outer points need to be attached to the clones so that the splines dynamically follow clones….
    Ashish Gupta
  • Adam Trachtenberg
    June 7, 2013 at 4:29 pm
    Ah, well, that’s going to be a bit of a chore. You’ll have to create a null for each clone and attach it to the clone via Xpresso. Then you’ll have to create a Hair>Constraint tag and constrain each end point to the appropriate null. Here’s a scene where I’ve done it for a couple spline segments: 6120_splinepointstoclonesamt.c4d.zip
