Activity › Forums › Apple Final Cut Pro › ATI Radeon HD 5770, macpro1,1 2007, 2 DVI Monitors, will it work
  • ATI Radeon HD 5770, macpro1,1 2007, 2 DVI Monitors, will it work
    Posted by Ben Edwards on January 22, 2012 at 12:53 am
    Cant quite work out which of the forums to post this on, if I got it wrong sorry.
    I got a 8800 GT card for my Macpro1,1 2007 (so I can run FCPx) and it turns out there are two versions, I got the wrong one and it does not work.
    I could get a 8800 GT that works with my Mac Pro but am thinking it probably makes more seance to get a 5770, I have heard works well with FCPx and Resolve Lite.
    So, can anybody confirm this will work with my Macpro1,1 2007 with FCPx and that I will be able to use my two DVI monitors?
    This post – https://blog.macsales.com/6856-owc-reveals-which-radeon-video-cards-work-with-2006-2009-mac-pros – looks like it will work.
    Lastly (Bit OT I know, sorry) I am a little confused as t what connectors I would need with this card to connect 2 monitors with standard DVI, any insight would be great.
    Regards,
    Ben
    PS I am a student so buying a new mac is not an option.
    Ben Edwards – Freelance Filmmaker
    https://www.funkytwig.com
    Nick Toth replied 14 years, 8 months ago 3 Members · 2 Replies
  • Paul Figgiani
    January 22, 2012 at 3:36 am
    Ben,
    I’m running a similar setup. The 5770 works and no problem running FCPX or Motion. The card has a single DVI output and (I think) two mini display outputs. I’m using a mini display to DVI adapter for my second display.
    -paul.
  • Nick Toth
    January 22, 2012 at 5:08 am
    Similar setup here. Works fine. Paul is correct about the 5770 configuration (single DVI and 2 mini). I’d suggest putting as much RAM in your MacPro as you can also.
    NT
