Activity › Forums › Apple Final Cut Pro Legacy › ATI Radeon 9600
ATI Radeon 9600
Posted by Juan Carlos on February 9, 2006 at 11:21 pmHi all My G5 has the 9600 im trying to do color corrections on a high def monitor,, now the ouputs on the card are not labeled there are 3 sdi connectors,, are these rgb and i need and rgb cable to go out to the high def screen , or do i go out with a single cable, whats the best setup..
Juan Carlos replied 20 years, 7 months ago 3 Members · 8 Replies -
Shane Ross
February 9, 2006 at 11:33 pmSorry…looking at the specs for that card now and I am not seeing anything you are mentioning. The ATI 9600 is a graphics card with an DVI, VGA and S-Video out. No component or SDI.
Are you sure you are talking about the 9600 GRAPHICS card? Graphics cards aren’t suitable for color correction output. You need an HD capture card, like the Decklink or AJA solutions.
Alokut Productions
Joseph Bradley
February 9, 2006 at 11:33 pmThat’s wierd, I have an ATI 9600 and all it has is a DVI and a VGA connector. Are you sure you aren’t looking at some other card?
Juan Carlos
February 9, 2006 at 11:49 pmi just sat down in this machine,, in the about this mac it says 9600 radeon , but there are 3 connectors out of it,, they look like svi,,they are unlabeled,, thats what im trying to figure out …
Shane Ross
February 9, 2006 at 11:53 pmSounds like you have a Decklink card installed in there as well. Either an SD or HD card…they look the same from that angle.
What you need to do is ask the people who own the machine what card that is, and how to hook it up. if you don’t know, don’t do it.
Alokut Productions
Juan Carlos
February 9, 2006 at 11:59 pmChipset Model: ATY,RV351
Type: Display
Bus: AGP
Slot: SLOT-1
VRAM (Total): 128 MB
Vendor: ATI (0x1002)
Device ID: 0x4150
Revision ID: 0x0000
ROM Revision: 113-A58504-113
Displays:
Cinema HD Display:
Display Type: LCD
Resolution: 1920 x 1200
Depth: 32-bit Color
Core Image: Supported
Mirror: Off
Online: Yes
Quartz Extrem
Shane Ross
February 10, 2006 at 12:02 amOK…yes…you are looking at the GRAPHICS CARD INFORMATION! The card you are describing is not a graphics card. Look at the back of the computer again…see where the computer monitors are connected? THAT is the graphics card that you are listing.
If you look in the profiler under PCI Cards, you will see one that says PCI-BRIDGE. That is the capture card, but doesn’t say what it is (I have a Decklink HD card installed).
You really need to ask the people who own this computer.
Alokut Productions
