Activity › Forums › Avid Media Composer › athlon processor
athlon processor
Posted by Lerap2 on July 12, 2006 at 1:46 amwill avid programs run on using AMD athlon 64 processor?
Please advise.
Jay.Don Logan replied 20 years, 1 month ago 5 Members · 4 Replies -
Matt Wafaie
July 13, 2006 at 10:15 pmI run AVID express pro HD on a dual core 64 AMD athlon without a hitch. Had to upgrade the video card though. The system runs better than my dual pentium 4 at my office. Very clean.
M@
Ben Wharton
July 14, 2006 at 12:49 amYou just can’t use Windows XP 64-bit version yet.
Also – you’ll need to watch which version of Avid you have (assuming Avid Xpress Pro here) – several versions have a codec issue with AMD processors which means that footage after it has had an effect applied to it will exhibit green lines all over the frame.
There is a work around in using an older codec pack (making HDV compatibility zero).
Hoever, the latest version of Xpress Pro (5.5.1) may have solved the AMD/green line issue. I’d check on the Avid forums. As well as the spec. You may well need a better/different graphics card as everything is now driven by Open GL.
Don Logan
July 19, 2006 at 1:01 amUsing a AMD 4400 64bit dual core…..Rock worlds. Intel pintel is losing market share fast. It’s not the size of the dog in the fight it’s the size of the fight in the dog and the underdog fights Hard. AMD Baby.
