Activity Forums Blackmagic Design ATEM Workflow Questions
  • ATEM Workflow Questions
    Posted by Tracy Peterson on October 17, 2011 at 5:05 am
    I’m working on a live show with our demo unit from Snader and Associates and I keep running into issues that I feel like there must be a better way to get them done.
    1: What are the actual file formats? More than just TGA or whatever. What should the settings be, bit depth, size, etc.
    2: I have run into an issue with using a numbered image stack as an animation, where the ATEM doesn’t seem to respect the numbering scheme, should the numbers be presented in a certain way? PNG seem to work, if I don’t use the 0 frame, but have issues with various types. It seems the media player starts the animation from the middle frame, resulting in incorrect playback.
    3: How can PIP with a frame be accomplished with the keyers?
    4: Sometimes a key works, sometimes it doesn’t. I am not sure if I’m using correct images, so I can’t really tell if I am getting a good test anyway. PNGs seem to work best so far.
    5: Can the software eventually have more than just a smattering of key commands? I realize this conflicts with the broadcast panel business, but if the software was more open, it would make the device much more versatile.
    6: Is there a plan for an IPAD app?
    7: The photoshop plugin doesn’t seem to work. The key simply doesn’t work.
    8: How can I create an animated lower third? I want to have a blank third animate in, revealing another key, which would just be the text, is that possible, or can I only have still thirds?
    SO MANY QUESTIONS. Maybe I’m asking stuff that seems obvious to people who have used these switchers but please clue me in.
    Tracy Peterson
    http://www.onetwomany.com
    Tracy Peterson replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
