Activity Forums Blackmagic Design ATEM TVS – Bad Port
  • ATEM TVS – Bad Port
    Posted by Randy Ovaskainen on June 14, 2012 at 2:42 pm
    I bought a brand-new Atem TVS and whatever I do I cannot get port 3 to work in either HDMI or SDI. I literally take a live feed from another port and plug it in and nada.
    Has anybody else experienced such a thing? I emailed BMD support and they’ve been lights out since Monday.
    Randy
    Randy Ovaskainen replied 14 years, 3 months ago 2 Members · 2 Replies
  • Chris Pearse
    June 15, 2012 at 1:39 am
    Hi Randy,
    The most common reason for a signal not working on port 3 or 4 on the Television Studio is having it set to the wrong connection in the settings tab of the ATEM software control panel. It seems that you’ve tried both connections, so I can’t imagine this is the problem, but I would check again to be sure. It seems more likely there could be a problem with the unit, but I would suggest calling support in your region to see if there’s anything further that could be a problem.
    You can find the support numbers for each region on the following page:
    https://www.blackmagic-design.com/company/
    Chris Pearse
    Blackmagic Design
  • Randy Ovaskainen
    June 15, 2012 at 2:37 pm
    Thanks for the reply Chris. I heard back from one of your colleagues yesterday. I mentioned that I tried good feeds in both and switched the SDI/HDMI settings and nothing.
    I am looking into getting it serviced but for now I actually need to keep it since we’re streaming the World Series of Poker and I have it working with the 5 cameras right now.
    Randy
