Activity Forums Blackmagic Design ATEM Relevision Studio questions
  • ATEM Relevision Studio questions
    Posted by Jim Gustafson on March 23, 2016 at 9:31 pm
    I need some help if anyone is a guru with the Blackmagic ATEM TV studio.
    1. I am getting intermittent “blinking”. It does it on main program feed as well so it’s visible to the audience. It’s only a frame or two of a flash, but is still a problem. I’ve tried. Different cameras and cables. I’ve tried running it through a power conditioner and also directly plugged into the wall. Has anyone had this issue before? Have a fix?
    2. Is there a way to get a Red scarlet into the ATEM television studio? It works at 720p out from the Red, but I need to be running at 1080i 59.94 because none of the other cameras can do 720p. (Sony a7s & Atomos Shogun and 2 Sony rx10 ii’s). I here it might work with the BMD updowncross converter. I have an Intensity Extreme can it convert any output signals from the Red into 1080i 59.94?? Any other work-around a??? Thanks!
    Jim Gustafson replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
