Activity Forums Blackmagic Design ATEM Camera Converter -> Tally Information
  • ATEM Camera Converter -> Tally Information
    Posted by Thomas Petzold on July 31, 2014 at 4:15 pm
    this is a part of a former Post
    Hersh Burston ->
    The ATEM Camera Converter will accept Tally information sent down the program line of the ATEM switcher. This is a data packet in the SDI stream which can be read by the converter. The converter has a button to select the camera number to match the camera number being sent from the ATEM Switcher. This can also be setup via the converter utility.
    Kilian Hirt ->
    Hi, thanks for the reply.
    So this means it is not possible to use this system with other live Video Switchers? This use of the data packet in the PGM stream is only done by blackmagic?
    Hersh Burston ->
    “This is correct, but we will make the information available so that others can use it as well if they choose.”
    The question now is: Where I can find this information? I have found only the Information how we can setup a Studio Camera by ANC Data.
    Regards
    Thomas Petzold
    Thomas Petzold replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
