Activity Forums Blackmagic Design ATEM Audio level difference between analog and digital outputs?
  • ATEM Audio level difference between analog and digital outputs?
    Posted by Tim Veal on December 21, 2011 at 11:49 pm
    Has anyone else had a difference in levels between the analog and digital audio outs? I’m using the ATEM 1 M/E switcher with the software control in a church and can’t figure this out. Audio is mixed on a mixer with peaks at 0 on the VU meter. From the mixer it goes into the ATEM via the analog XLRs. The analog XLR outs go into a DA that feeds several consumer HDTVs. Digital audio comes out the program HDMI (with the video) and goes into a Matrox MXO2 Mini that is used with a laptop for streaming on our website. The problem is I seem to either have good analog levels and the digital audio is really low (peaks at -20dbfs on the Ultrascope) and barely audible on the stream, or I boost the audio out and get good digital levels (peaks at -8 dbsf on the Ultrascope) but all the tvs are overloaded. It’s not the MX02 Mini because when I hook a camera up to it instead I get good audio levels on our streaming. Also, does anyone know what level +/- db the ATEM is expecting for audio in? I can’t find any info on this at Black Magic.
    http://www.sandstoneproductions.net
    Tim Veal replied 14 years, 8 months ago 3 Members · 4 Replies
  • Justin Strauber
    December 22, 2011 at 4:27 am
    0 VU in a digital world is typically around -20dbfs. So, working as intended.
    Jack up the input levels on your streamer rather than on the output of your board, you should have less of a problem with overmodulation and get the ‘loudness’ you’re looking for.
  • Tim Veal
    December 22, 2011 at 3:45 pm
    The steamer (Adobe Flash Media Live Encoder) already has the volume up as far as it will go. A camcorder (HV20) hooked directly via HDMI works great. It must be sending out a hotter audio signal? As for the ATEM levels, during a event most of the time they are between -40 and -30 dbfs. Only peaks hit -20 dbfs. This seems low to me? When I edit, I mix to have most sound hitting from -20 to d -12 dbfs with extremes hitting -6 or so.
  • Jeff Hartman
    December 23, 2011 at 2:18 pm
    Just a bit of background to help you interpret what’s going on…
    Unlike most units of measurement, decibels are a relative measure, always compared to something else. It’s not like measuring X volts or saying something is N inches long; rather, it’s like saying a signal is three times more than… something. So a reading in decibels is not just the bare number; you also need to know what that “something” is — the reference.
    In the world of analog equipment, one use of decibels is to describe the voltage of an audio signal; the reference used is the amount of voltage that you have when the signal delivers one milliwatt of power into a 600 ohm load. That measurement is usually shown as dBm (the “m” signifying “milliwatt”). Most professional analog audio gear nowadays uses +4dBm as the nominal operating level; back when I started in television, +8dBm was the more common reference level. Generally speaking, most analog equipment is capable of handling peak voltages around +24dBm, which means there’s about 20dB of headroom above the nominal operating level before clipping begins. The exact point of clipping varies from device to device, so a systems designer needs to be mindful to avoid serious mismatches that would lead to early distortion.
    Now if you look at a piece of analog equipment with a VU meter — a console or tape recorder will do — you’ll see a scale in decibels with zero about two thirds of the way to the right. This is measuring level with respect to the nominal operating level. So if you have a mixer that has a +4dBm reference level as its standard, you will see +4dBm when the meter reads 0; drop the level so the meter reads -10dB, and the output voltage will drop to -6dBm. Raise the level to +6dB, and the output becomes +10dBm. Where analog VU metering falls short is in representing peaks; very few analog meters go anywhere near the typical clipping point of +20dB VU. But in the analog world, it’s pretty unusual to spend any real time there; moreover, a lot of analog devices can handle these overloads fairly gracefully.
    Digital equipment, on the other hand, does not suffer overload well at all. There’s no room for “just a little bit more”; once the numbers hit the maximum value, that’s as far as things will go. And voila: instant clipping. This is such a serious issue that a great many digital devices measure audio in terms of that brick wall limit: and the measurement is dBfs, decibels with respect to Full Scale. Since the reference is the maximum possible value, that makes all dBfs measurements a negative number (which is the first thing that tends to hang people up). As a general case, most digital gear makes the assumption that the normal operating level is 20dB below the maximum, so for these devices -20dBfs will show as 0 VU, and will produce +4dBm on an analog output.
    So… how does this play out in the real world? If you have a typical system with a mix of analog and digital equipment and throw tone on your mixer so that the VU meter shows 0dB, you should expect to measure a voltage of +4dBm on an analog output; feed it into a digital recorder, and you should see a reading of -20dBfs. This is entirely normal, and is exactly what you should be shooting for.
    I could go on about the differences between average versus peak metering, but that’s more intuitive and not directly pertinent to the issue you’re having.
    Regards,
    Jeff
    Jeff Hartman
    Engineering Project Manager
    Newport Television, Northeast
  • Tim Veal
    December 23, 2011 at 4:18 pm
    Thanks for the in-depth explanation Jeff. I ran tone and that is what I was getting. I think I have narrowed the problem to the MX02 Mini/Flash Media Encoder Live combo. Somewhere there the audio is getting mismatched.
    By the way, if anyone wanted to know Blackmagic said the 1 M/E is balanced +4DB audio via the XLR cable.
