Activity › Forums › Blackmagic Design › ATEM 2.6 Update
ATEM 2.6 Update
Posted by Ronak Desai on October 10, 2011 at 8:54 amI’ve been anxiously waiting for the USB 3.0 update (Version 2.6) for the ATEM Production Switchers. Does anyone know if the output on the USB will work with Adobe Flash Media Live Encoder? I currently do not own one….yet.
John Williams replied 14 years, 11 months ago 4 Members · 4 Replies -
Matt Drabick
October 11, 2011 at 2:39 pmRonak, I will test this is soon.
The ATEM 2.6 addes the following:
• Uncompressed capture via USB 3.0 with ATEM 1M/E Production Switcher
• UltraScope monitoring via USB 3.0 with ATEM 1M/E Production Switcher
• Support for tally via Ethernet with the Blackmagic GPI and Tally Interface
• Support for tally via SDI to the ATEM Camera Converter
• General performance and stability improvementsShould be interesting!
Matt Drabick,
DigiTek Systems -
Dean Anderson
October 12, 2011 at 5:29 pmDo you know if this also includes being able to use Quicktime and AVI clips in the media pool? Also, have you attempted to capture yet with the USB 3.0, and do you know if that includes compatibility support for Adobe OnLocation/Premiere Pro?
Dean Anderson -
John Williams
October 21, 2011 at 9:32 amI have just installed the 2.6 update and can’t get either Media Express or Ultrascope to work. The upgrade all went OK and the software installed to the main unit OK. I have checked the NEC Chip software as well to make sure that it is OK.
Has anybody seen this all working?
Regards,
John
