Activity › Forums › Blackmagic Design › ATEM 16:9 SD input
  • ATEM 16:9 SD input
    Posted by Raphael Schricke on November 18, 2011 at 2:53 pm
    I am thinking of buying an ATEM TV Studio for our live productions.
    My question is : I read that you can input a SD Pal signal 720×576.
    But what if it is in 16:9 instead of 4:3 ? Will this be an issue for the ATEM Switcher ?
    Will it show the video in the good 16:9 format in the multiview and in the program ?
    Thanks a lot for your help.
    Eric Van engelen replied 14 years, 10 months ago 2 Members · 1 Reply
  • Eric Van engelen
    November 21, 2011 at 9:35 am
    At this moment is can process your signal. But the multiviewer shows it as 4:3. Which makes the switcher quite unusable in SD-productions.
    I’ve mailed with Blackmagic several times since early august, but they won’t give a timeframe for when they will fix this issue with an update.
    Until then we’ll have to rent a another switcher for each SD-production, which is **#* annoying.
