Activity Forums Blackmagic Design ATEM 1 — USB/3 Capture
  • ATEM 1 — USB/3 Capture
    Posted by Carlos Morales on April 25, 2012 at 4:05 pm
    I have an ATEM-1 hooked up to desktop via USB 3. MediaExpress shows only color bars when I select it as a source. Media Express works fine with our ATEM-2 (via USB 2) and with our h.264 Pro Encoder.
    The desktop has a NEC/Renesas USB3 controller with Driver 2.1.32.0 and Firmware 4015 — which seem like it would be sufficient per BlackMagic’s compatibility doc.
    Any ideas would be welcomed.
    -carlos
    Carlos Morales replied 14 years, 4 months ago 2 Members · 2 Replies
  • Justin Strauber
    April 25, 2012 at 4:22 pm
    Have you changed the output of Aux1 on the ATEM to something other than bars? Also, have you tried running UltraScope to see if you get the video you’re expecting?
  • Carlos Morales
    April 25, 2012 at 4:29 pm
    Thanks!!! All I had to do was change “Aux 1” to Program Out rather than bars.
    It is working with both my Desktop and a Dell XPS 17 laptop.
